ImStricken wrote:its normal when the uneven wear is a 1mm or 2.5mm from one another.
but its not normal, at your numbers. i would check the slider pins in the tiny rubber boots(the springy look rubber boots on the caliper itself. there are two of them). i wouldn't be surprised if you have a seized caliper piston.
How would one test and diagnose a stuck piston? When I recompress the piston with a c clamp, would it not retract if it was seized?
Braking performance in this car seems to be outstanding, especially considering the weight, with no pulling to either side when braking.
