UnDrift my Hood-Hood is crooked
Y So Low
Car: Cars
Hey guys,
I was changing my oil today and when i put the hood back down one side is higher, much higher than the other. that side now looks like it is a drifter hood. how can i fix this? i tried to tighten the hinge but still the same. nothing was in between and the hood never closed with something in there.
This sucks never ending story :help
bodyman240
try adjusting the hood stops up on the one side
Y So Low
Car: Cars
well its actually really high right now, so i don't think by it going up will help, i need to get it down and the hood stop is down. how i hate this
1991240xs
leave a tool under the hood maybe??
Structure240sx
i did that to mine slammed it with a socket wrench on the strut tower made a gap of about 3mm but i can see it all the time
topless@vabeach
Car: Electronics, anything that has trons in it.
Use your hood stops to adjust it like Bodyman240 said. They are the black round plastic/rubber things located on each side of the front end. The low side counterclockwise about 2 turns and twist the high side clock wise 2 turns and check it out. Tweak it from there to align it up. They might be a little worn out so you might have to really pull up on them when you are twisting counterclock wise and push on it when going clock wise
Y So Low
Car: Cars
1991240xs wrote:leave a tool under the hood maybe??
no.
the back of the hood is unaligned not the front. the stopper will adjust the front and not the rear. correct?
GatorS14
Car: 93/s13/white,96/s14/crashed...ask about parts
a drifter hood? please explain
Y So Low
Car: Cars
GatorS14 wrote:a drifter hood? please explain
drifters in japan lift the top part (the part closest to the driving compartment higher) just a japanese thing.
GatorS14
hmmm..thanks
does it look better?
s0ldats
Y So Low wrote:drifters in japan lift the top part (the part closest to the driving compartment higher) just a japanese thing.
actually no, you're wrong. this is done since things on their engines are too high up in the bay. eg: strut bars
yeswepromise
or to let out all heat from the SR.:)
s0ldats
yeswepromise wrote:or to let out all heat from the SR.:)
word :)
Y So Low
Car: Cars
s0ldats wrote:actually no, you're wrong. this is done since things on their engines are too high up in the bay. eg: strut bars
ummmmmm no. its to let the heat out actually.
s0ldats
it's both. if you haven't noticed, people like fabricating/mix-matching parts for their cars. some parts fit better than others. strut bars are easy to find, some fit better than. thus putting spacers in the hood mounts to make it clear the poorly fitting/cheap strut bars.
yes, it is also done to let hot air escape, but obviously you had no idea what i was saying.
"drifter hood?"
OHHH MAN!! gotta go!! my option video came in the MAIL~! THEY HAVE LOTS OF DRIFTERS WITH DRIFTER HOODS!!! :rolleyes :rolleyes
slw240sx
Car: 1990 Ca18det 240sx Hatch
its your hood hinges bending as you close the hood ! mine did this and i eventually broke the hinge try some liquid wrench on the hinge point and push down on it,
SmithSR
Car: 240sx
Yes, hinges go bad on alot of cars, no surprise there....just usually not on anything newer than '75 or so...
nismojason
Yeah i just found out that this is happening to my car the other day. the hinges, the acual rotating part rusted itself together, so when i opened the hood the hinge just bent itself and then is off when you close it too. I'm just going to the junk yard to get a coulpe.
Y So Low
Car: Cars
slw240sx wrote:its your hood hinges bending as you close the hood ! mine did this and i eventually broke the hinge try some liquid wrench on the hinge point and push down on it,
today was the first day over 30 in a while so i took a close look at it and the hinge is bent, wonder how, but its that. know how much a new one will be?
nismojason
I'm going to the junk yard maybe tomm. (wed.), and if i can find another set i will get them, they probably won't be more than $10 or so for a pair.
slw240sx
haha good luck finding them took me almost a year to find one hinge, every car i looked at has either no hinges or the passenger hinge left on it, and i needed the drivers side hinge!! yeah the rotating part gets stuck togther and causes that hinge to just bent up an down...
Y So Low
Car: Cars
well if you find the passenger one, that is the one i need
