bhs07c »
https://forums.nicoclub.com/bhs07c-u120529.html
Mon Aug 03, 2009 5:57 am
Hi guys,I have a 2007 Nissan Altima 2.5S 4dr w/ Manual Transmission (About 23,500 miles)Last Friday (July 31st), I was on my way to the gym on I-495 (Capital Beltway). I hit 5th gear at about 65/70ish mph when all of a sudden every single warning light popped up and the next thing I knew, my car had turned off and I was left without gas, power steering, and power braking. Fortunately, by some miracle, I was able to abruptly pull off and stop, about 1 inch away from a guardrail. The following Monday, I took my Altima to the Nissan dealership. After running several tests, including a high speed test drive on a toll road, they found nothing wrong. Obviously, the last answer I wanted to hear. I then asked if the advanced timing I had recently tuned had anything to do with it, considering if that is not done right can cause bad engine damage and problems. However, the mechanic (who was also the one who did it for me with the Consult III programmer) said -2 degrees is not a big enough tune to cause an engine to stall that way. Besides he added, with the Bully Dog Triple Dog GT Gas Tuner on it's way, I figured I'd just retune everything then. So, now here I am, scared ****less to continue driving my car when I know something isn't right. Ever since that happened, my acceleration sucks and my brakes and steering have been stiffer. I need somebody to help me ASAP. It's obviously not something detectable w/o a "Check Engine Light" so any other ideas? Could the Advanced Timing be messing up my engien and if so, should I let the Bully Dog tuner fix everything or is there something else that is potentially wrong with my car. Please helpThanks
