Understanding the Profec B Spec 2
BaliLover
I just got a Profec B spec 2 and upon reading the manual discoverd that its not as simple as I figured it would be. Its not just a of setting a simple PSI figure, instead it wants a percentage.
Where/how do I figure out this percentage. I'm running a Garrett GT28RS with its stock wategate actuator and I think thats set at 7psi. How am I supposed to use that number to determine a %? Or is this more of a trial and error, drive it and turn it up, drive it, turn it up type thing?
mynismo
trial and error... watch your boost gauge and just keep adjusting.
SoCalS14
Car: My car...duh
Use google and search, I found a really good tutorial on a SRT-4 Forum.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
Well, they profec B spec 2 has a build in boost moniter. The manual pretty much explains everything (0% = boost controller lets the wastegate open as soon as posible and make the lowest boost, 100% makes the wastegate stay closed and make the highest boost posible)
The profec B spec 2 is more of a tuning device than a simple boost controler. You can dial out spike and creep, its totally awesome.
f150intally
best advice i can give you is throw out the manual. its really not complicated at all. there is a good writeup on freshalloy in the best of 240. John from Secret Services wrote it and he has tuned 100s of cars using that boost controller.
Nismo1182
Car: Z06
You can also switch over Kpa to PSI. Its in the manual. So instead of setting a percentage, you can set it to the EXACT boost you want. 100 will then = 10 psi, 140 = 14 psi and so on.
Onizuka
Somebody did mess up writing (translating?) the manual at parts, but it has excellent tips on how to used the different functions. At first my car was getting really bad creep, fiddled with the settings a little and now I get boost by 2000rpms and rises quick from there.
caliracer240
Car: cars and chicks
boost by 2000 RPM's on stock turbo?? i dont hit till around 2800-3000 RPM's on my stock and the prefec b spec 2.
boost = 43%gain = 15%set gain = 780
Thats my high boost setting i get 14.6 all the time but if i cant, i want the boost to hit quicker.
Onizuka
Brand-new ball bearing T28.
BaliLover
What are your settings, just curious.
BaliLover
OKay, heres what I have right now.
In Hi setting, I have 44% set, 10%gain, 100 set gain, 175 warning, 8% limiter.
In Lo I have/had 35% set, 10%gain, 0 set gain, 175 warn, 8% limiter.
In high mode, it seems to take boost a bit longer to kick in, but when it does, it really nails you back in the seat and will break traction hard at the top of first and way into 2nd. 14.7 seems to be the average boost, with a spike around 15.7. I've still got some toying around to do.
Now the odd part is in low, with 0 start boost which should make it boost slower, I actually got a spike of 16.3 and my max average boost was around 14 so something seems odd. I dropped the set% to 30, and set the start at 80 and now i'm sitting in the 12psi range.
This thing really seems to be luck of the draw as to what % you need to set to hit a certain boost level.
Nismo1182
Car: Z06
If you need help, im in central fl also.
BaliLover
I had more time to play with it today. During the day my high settings were just a bit too high, average of 15.5psiand high of 16.3, with a 45% set, 10% gain, and 100 start. Tonight there was no one on the roads and it was cooler so I was playing a bit harder, and was doing an average of 15.9 with a peak of 16.6, so I turned it down to 40% and that seems to keep me within 15.5 consistantly.
NOW, I decided to try the low setting at 18% set, 10%gain, and 80 start, and I pulled an average of 13.4. Whats the deal here, I'm using less than half the high settings set boost, and I'm just barely lower. I've got it down to 12% now and its still hitting 12psi and peaking in the 13s. I had to get off the road because I saw a few cops go past and figured they probably heard me testing so I couldn't finish.
But something about this thing seems weird. There are no boost/vaccume leaks, all the plugs are removed from the solnoid, its hooked up correctly, but I still can't get consistancy of any kind, and when the temperature changed, it seemed like all the settings that I thought were perfect, are now useless.
BaliLover
Oh, I forgot to mention, I'm running a stock SR with a Garrett GT28RS and I believe the internal wastegate is an 11.5PSI unit.
Nismo1182
Car: Z06
Switch it over from the % to PSI. Its easier to use that way.
Where were you testing at?
f150intally
BaliLover wrote:Oh, I forgot to mention, I'm running a stock SR with a Garrett GT28RS and I believe the internal wastegate is an 11.5PSI unit.
BailLover,your limiter is set wrong. It needs to be set like this. if you want to subtract 8 % from your high boost set it at 36%. same for low boost. it is set the same way as set boost.
BaliLover
I am using the PSI, but it still requires that the set boost be done in %, the only figures that are set in PSI are the Start Boost(set gain) and the warning. It will also display the current boost and peak boost in PSI.
F150, I figured out the limiter was wrong yesterday and I readjusted it properly, but that wouldn't have anything to do with me not being able to get a stable boost.
I slept on it and realized that with my wastegate being an 11.5psi unit, I will never be able to get 10 PSI from it because you can't boost less than the wastegates setting with the Profec, so I'm going to set my low boost to 0% and see how that works.
BaliLover
OH, I was testing on a 4 lane highway at 1am with no traffic going my direction.
