I recently change my water pump on my infiniti 1995 j30.Noticed that my crank pulley was a little bent up.So i decided to try a new underdrive crank pulley alot smaller in diameter.Needed certain sized belts that a nissan specialist recommended.Installed and put everything back together.When I start the car.It starts great,Idles fine for about 15 seconds then stalls like it ran out of gas.My question is,Do I need to adjust the crank sensor and check fuel pressure?Do you think this will help.
Modified by casanova7969 at 9:03 PM 10/14/2009
Modified by casanova7969 at 9:06 PM 10/14/2009
