underdrive pully help
jkilby18
Car: 1991 300zxtt
so why my motor is out im gona change the cam seals and front main... but i can not for the life of me ge the underdrive pulley bolt loose.. ive used penetrating spray and a air gun and it still wont budge.. any ideas ?
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
How strong an impact gun are you using? I can put more than 500lb/ft of torque on a breaker bar with a cheater bar. I'd try that and getting something to lock out either the cam gears or the flywheel.
jkilby18
Car: 1991 300zxtt
i ended up using a breaker bar and my old alternator belt and wraped it around the alternator housing.. i seen it some were on this forum and it worked amazingly
NolimitZ32
usually you want to lock up your FW against the block, its safer than using belt that could slip.
