tonynalli wrote:you have gotting to be kidding me thinking that you dont need the balancer. do yall even know what they do, the company didnt put them there just because it would add wieght. its a weighted thick metal piece that turns with the rotation of the engine, to counter balance the vibrations caused each time the gas and air mixtures explode when ignited by the spark plugs. you will destroy your engine if you remove it. would you rather loose a few pounds right now or have to rebuild your engine in a few thousand miles?
Calesta wrote:No kidding. Harmonic balancers are used to smooth out the power pulses, not to make sure that the rotating assembly is balanced. The two types of "balancing" are completely different. Maybe the harmonic balancer should be called a "power smoother" instead of a balancer.... it would be more accurate. You need a harmonic balancer to make sure your engine lives a long life. You can remove it to recover some of your rotational losses, but you lose engine life as well.
tonynalli wrote:you have gotting to be kidding me thinking that you dont need the balancer...
DGA wrote:Not entirely true. I know that Honda engines do not have an external balancer, just a crankshaft pulley, just like KA24DE does.Engines can be internall balanced.
I also have a vintage Chevy truck with a small block in it, and they are not internally balanced from the factory, thus needing an external harmonic balancer. You can remove the harmonic balancer if you get an internall assembly that is fully couterweighted and balanced. Guy I worked with had a '67 Camaro with a 327 in it, that he could hold at 12,000 rpm. He ran a harmonic balancer just due to the rev happy nature of that engine. It all depends on what you got spinning in that block.
DGA wrote:Yeah I know, I put my own foot in my mouth on that one. Man I could have sworn, that they were not internally balanced. So the only point of the harmonic balancer on those things is to smooth out the vibrations of a V style engine?
KADE is a cam on bucket design. No rockers. I am positive on this one.![]()
