Underdrive Pulley Set, Polished, 03-07 350Z Quantity in Basket:noneCode: 10-2195Price:$329.95
Quantity: Description:Unorthodox Racing Ultra Street lightened under drive crank pulleys are made of premium lightweight 6061-T6 billet aluminum to ensure consistency of the material's strength and balance. An average of 5 to 12 HP and 4 to 8 lbs.-ft. on normally aspirated engines and 8 to 16 HP and 8 to 18 lbs.-ft. on forced induction engines can be gained. Higher gains may be possible on certain set-ups. For example, tests on one Nissan 300ZX twin-turbo saw gains as high as 37 HP and 45 lbs.-ft. on the dyno. Power gains are obtained by weight loss and underdriving. Underdriving on Unorthodox pulleys is maximized for power, but not at too great a ratio in order to keep charging systems, air conditioning, power steering, and water pumps moving fast enough for every day driving HOPE THAT HELPED OUT. I ADDED THESE TO MY Z AND YOU CANT TELL A CHANGE IN HORSEPOWER EXCEPT ON A DYNO, BUT YOU WILL GET THRU GEARS TWICE AS FAST.
http://www.webspawner.com/users/drewh24/
