Underdrive pulley
Timos240
Car: '95 240sx not quite stock,
I am looking for the pros and cons of a set of underdrive pulleys.What kind of horsepower gains can I expect? Will it noticably affect the electronics of my car? Etc.Any advise is welcome.Thanks
MikeMurphy
Car: Guess
Power gains throughout the power band. Off the top of my head if I forced a guess I would say maybe 6hp.
Just dont hook up an extensive stereo or anything that will make a big drain on the electrical system.
Excellent all-around upgrade.
Timos240
Thanks for the info.What brand and where is a good place to get them?I can get a set of four pulleys (Unorthodox Racing) from a local speed shop for $472. Good/Bad deal??
1995 240sx
i got a full set the crank ps alt wp for $305 from UR online they were having a sale on some discontioned modles
I put all them on and estamate a few HP but the biggest thing is that the moter wants to rev faster make much easier to downshift
the alt is a problem though it does fine when running but at idel the light dim just a little and i am running a red top battery. The alt pully was just a hair bigger then then stock on so it helps a little but i think that they do make bigger pulley for alt if u r running a high watt stereo
1995 240sx
This was my first mod and used the info on the install section to do the install myself took a couple of days to do but that was bc i was doing inbetween classes and studying
BUT well worth it in the long run in my book need new belts anyways and was happy to get that done at the same time
Timos240
Thanks for the tip.I just checked there website and their pulleys are 40% off.I think you just saved me about $200.
EnzoRWD
Car: 1997 Volvo 850 T5
they only list SOHC or S14? what about 91-94 DOHC? i hope the s14 works on the s13 dohc motors. i might need to get me some pulleys y0!-Enzooooo
