UnderdrivE PulleY???
tricktunes240
Car: 1992 240sx fastback
Ok i decided on Underdrive pulley possibly ASP, or is it worth the 100 more for Unortho...whats the differnece? Anyone install these and notice real diff....thanx again
TrueSlide
Car: Stuff
ThE DifferencE is OnlY a FeW OunceS. So ThaT is AlL up to YoU. I HavE ThE AsP.
aaroneezee
ASP is underdriven, meaning youll need all new different sized belts. UR is lightened, but uses stock belt sizes. iirc
Ichi-Go
I have an ASP sitting in front of me and it sure does feel a lot lighter than a stock pulley.
JesusLikesKFC
Car: 91 240sx, geo prizm
stock is 8lbs, either one would make a difrence, when i used to have my ka i had unothodox pulley and it def was smaller wieghing somthin around 3 pounds i think.... i remember going back and forth to autozone to get the rite size. its your call.
SPIRONIUM
Car: 240RS group 2
UR is ALSO underdrive, i'm selling one on ebay right now heh heh
onosqv
Car: '92 240sx Vert
aaroneezee wrote:ASP is underdriven, meaning youll need all new different sized belts. UR is lightened, but uses stock belt sizes. iirc
Only 1 or 2 belts are still stock sized, same w/ ASP.
I have a UR, but that's only cuz I got one used for 100, haha.
Been working great for 1+ years. Remember to change the crank oil seal on the timing cover too!
tricktunes240
do you know which belts are different...? i dont have A/C so dont have to worry about that but what about the others? and do you konw the part number for liek a auto zone one...thanx
onosqv
Car: '92 240sx Vert
Easiest way is to bring your stock ones in & ask for 1 size smaller & 2 sizes smaller for both pulley belts. that's what I did.
I "believe" only the alternator one different - this was how it was for ka24e... you can search on the install instructions for the UR pulley & it tells you.
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
Enjukuracing.com has the ASP pulley for the S13 for $119 and it says it inculdes the new belt sizes. Easy enough, right? I'll be ordering mine in a week or two, gotta make a trip home first. And, yeah, change your front crank seal at the same time, just for good insurance, and please, for the love of cheap gaskets everywhere, use a genuine Nissan crank seal (the rear main was WAAAAAY better than aftermarket).
tricktunes240
great thanx...
MikeMurphy
Car: Guess
BIGT94z
does the asp make the same on a dyno as the ur...the ur gets about 1.5 - 2 to the wheels...what about the asp? it's a little heavier so won't it be less horsepower to the wheels? Just a thought
artemous
Car: 95 240sx Ka24de. 81 datsun king cab. 9 corvairs
I have an unorthodox sitting in the garage waiting to be installed. The old is out and the unorthodox is considerably smaller and much lighter. It feels more like the W/P pulley. I'll now in a bit if it made any difference. I'm sure it will affect the idle air conditioning in my 115+ degree Phoenix summers.
