Underdrive pulley (maxhopper97)
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
Scott, did the underdrive pulley make a difference? If so, what difference? I visited your car domain page, NICE RIDE!!! How do you like the RSB, and did you copy the Nissan man w/ Honda emblem from my avitar or from DaveB at max.org., that's where I swiped it.
maxhopper
Car: 02 Maxima SE 6spd
I copied the Nissan man image from somewhere a couple years ago...I don't even remember where. I should probably add some pictures of my SP2 exhaust on there.
The underdrive pulley is nice. I mainly noticed a difference between idle and 1500 rpm, in that it gets the revs up quicker. I guess any time you can take approximately 4 lbs off the rotational mass of the crank, it's a bonus.
I like the rear sway bar. I'm not sure I can give you an accurate review of handling gains since I installed it a couple of months before I got my Illuminas. It definitely lessens the feeling of understeer, and pushes it closer to oversteer.
Beancooker
Did you keep the same belt or need a different size? Hard to install or just time consuming?
maxhopper
The belt that goes on the alternator is a different size, but you can reuse the factory water pump belt.
Make sure you have access to one bad-azz heavy duty impact wrench to remove the factory pulley. It's a lot easier if you have a 5speed than if you have an automatic.
Beancooker
I really wish I had the 5spd, but just a slow shifting auto for now.
maxhopper
Me too.
Beancooker
Get a VB mod (shift kit) I hear they make a big difference. It's on my to be done list.
cullenj76
Car: 99 Q45t 04 SRT-4
beancooker wrote:Scott, did the underdrive pulley make a difference? If so, what difference? I visited your car domain page, NICE RIDE!!! How do you like the RSB, and did you copy the Nissan man w/ Honda emblem from my avitar or from DaveB at max.org., that's where I swiped it.
RSB+EnergySuspension poly FSB and end-link bushings=
The poly FSB bushings and end-link bushings made the biggest improvement in the handling my max and it was only a 20-30 dollar mod.
Scott, Dave, I, and a couple others installed our RSBs at around the same time. Scott's description of going to nose-dive understeer to boderline oversteer is on point.
nismo1219
Car: '12 Nissan Altima 3.5SR
'99 Nissan Maxima GLE
maxhopper97 wrote:The belt that goes on the alternator is a different size, but you can reuse the factory water pump belt.
hey scott, do you know what size belt ill need to install this? like the part # or anything? also is there anything else i need to make the install easier besides just my set of hand tools??? i could use as much info and how-to advice you could give me!! thanks again!!
maxhopper
There's a how-to on the UDP install for a 99 here; your's should be the same. The last bottom of the hot-to has the belt sizes. I was able to find Gates belts at my local NAPA.
Link
