underdrive pulley kit.
zswap0429
Car: 1990 Nissan 300zx N/A (sold)
1990 Nissan 300zx Twin Turbo. (sold)
1993 Nissan 300zx N/A Convertible (sold)
1991 Nissan 300zx N/A (Project)
2009 Nissan Altima 3.5 SE 6spd.
Anyone know of a good brand for this? Z1 sells the AMS kit which is 2.5 lbs. And about $250. But ive never used any ams parts so im not sure of quality.
http://www.z1motorsports.com/product_in ... ts_id=2934
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
No. Do not support AMS, ALL their products are copies of others.
If price is an issue just get the ASP crank pulley, if not then Unorthodox
http://www.importpartspro.com/aspni30unpu.html
http://www.importpartspro.com/hovwapupufor.html
or
http://www.importpartspro.com/un30unpusew.html
zswap0429
Dang. That is $200 more then the ams. I know ams is just a bunch of knock offs... But if z1 supports them, they can't be that bad. I get the feeling this is allot like everyone's hate of non jdm bumpers
ThisIsSparTTa
Car: 91 300ZX TT 2+0
There's a brand new UR UD pulley that keeps the stock belt sizes so nothing is underdriven, but the pulley itself is still super lightweight: http://conceptzperformance.com/Cart/des ... .164.62.64
itsa300zx
2011 Nissan Rogue S
2008 Highlander SR5
zswap0429 wrote:Dang. That is $200 more then the ams. I know ams is just a bunch of knock offs... But if z1 supports them, they can't be that bad. I get the feeling this is allot like everyone's hate of non jdm bumpers
There are reasons for them being CHEAP.
StockTurbosFTW
Car: 95 300ZX TT
99 Infiniti G20
03 Kia Sedona
I can't find the link right now, but there is a bit where they weight AMS' water pump pulley compared to UD's.
Top is UR, bottom is AMS. Both are advertised as being 100% aircraft grade aluminum. AMS has the holes in it, reducing the mass, so AMS should weight less, right? Wrong. The UR one is lighter. Someone is clearly lying about the composition of their parts...
Found the link...
http://www.300zxclub.com/showthread.php?t=166452
In that link they talk about the misalignment issues with the AMS product, but here are the scale pics...
Personally, I would spend more money for parts that are made correctly and not cheap copies where they lie about the composition of the part...
zswap0429
Yeah. I could see ams using some cheaper stuff. I saw a lot of pictures of broken ams pulleys. So im not going for it
nissanfreak12
Car: 92 300zx 2+2 TT
StockTurbosFTW wrote:I can't find the link right now, but there is a bit where they weight AMS' water pump pulley compared to UD's.
Found the link...
Not that I support AMS, but the weight difference could very well be the thickness of the metal used. .4 of an ounce is so slight that we cannot see the difference, even if it is swiss cheese. Who is to say that the problem with pulleys are installation error, over tightening belt, poor engine maintenance, bad bearing causing the pulley to bounce or move more, etc... Yes what AMS does not the best business practice, but most businesses do not come up with the idea, they try and make it better and add to performance based products.
Fast, cheap, reliable. You can only have 2 choices. If you are worried about the price, either get it used or keep stock till you can afford it. If you are worried about reliability, keep it stock. If you want to go fast, or more power, do it right, or you will always working on your car with cheap parts.
