SX APPEAL wrote:Just a quick explanation of how a harmonic balancer actually works, since no one seems to have mentioned it yet... If you look closely at a stock crank pulley, you'll notice that its actually a center steel hub section joined to a separate outer steel ring by a thin ring of hard rubber. This allows the outer ring to move slightly separately from the inner section, due to the slight flexibility in the rubber. Why is this necessary? Because in an internal combustion engine, every time a power stroke occurs on one of the cylinders, the crankshaft accelerates very slightly, and on every compression stroke, the crankshaft decelerates slightly, of course these accelerations and decelerations are extremely brief and happen hundreds of times a second, so they will all blend together when observed with the naked eye. This is where the harmonic balancer comes in; when the crankshaft accelerates on a power stroke, the inertia of the heavy outer ring keeps it from accelerating at quite the same rate as the inner hub, as rubber between the sections flexes. This opposes the force of the acceleration and dampens the shock of the power stroke. Vice versa on compression strokes, the crankshaft and inner section of the pulley slow down, but the inertia of the outer ring provides the opposing force to this deceleration, dampening the shock of the compression stroke. This whole process happens, as I said, hundreds of times a second. This dampens harmonic vibrations that, if left unchecked, can weaken the crankshaft over time. Sorry if this post is a bit convoluted, I did my best, but its kind of an abstract concept. Now I realize why no one's gone to the trouble to explain it thus far
Almost, but it seems you have missed the actual point of this device, which is to dampen TORSIONAL vibrations, not the dynamic imbalance caused by the accel/decel of the crank pins. Torsional vibrations come from the flexibility of the crank pin arms on the crankshaft. They bend (very SLIGHTLY) under load (power stroke), and when that load disappears (around BDC), and they become "free", they begin to swing/vibrate/bounce. Just as any spring, if compressed, then released quickly. The possible problem with this is, if the frequency of these vibrations (frequency ~ RPM) comes very near to the
resonant frequency of the rotating assembly, the vibrations are going to stack up, amplifying themselves, until eventually, the amplitude of these vibrations, and thus, the stresses that they cause in the crankshaft become so high, that the crank breaks. (don't know the correct term for this phenomenon)
This is where the crank pulley/harmonic balancer/torsional damper comes in. The hard rubber+outer ring is tuned to absorb torsional vibrations of a specific frequency. The frequeny at which the vibrations tend to become the strongest, which is the resonant/natural frequency of the rotating assembly.
I would not replace the stock pulley with any solid part, that has no measures in place to reduce these vibrations. From what I understand, you can get away without one on an all out race engine, as those do not spend too much time at one specific RPM, so there's no time for these runaway vibrations to build up.
Recommended read (basically the whole site):
http://www.epi-eng.com/piston_engine_te ... orbers.htm
I've found some of the articles incredibly enlightening.
