Jacko3 wrote:Sentient:
That was my first concern as well---cooling. Will this under body aero allow for the more efficient colling of the transmission and other mechanical parts that tend to heat up under spirited driving?
If the venting is designed properly, then yes. The negative pressure just after the vents should pull the heat out of the engine bay.
With enough clearance, fans could also be mounted below, but I don't think there's enough space down there to do that.
I'd be interested in finding some high flow computer fans that can withstand the engine heat and mount 4 of 120 mm ones at strategic points. I once had an 80mm that pushed somewhere in the neighborhood of 84CFM. Once spooled up, it sounded just like a mini airplane jet engine.
