The underplenum hose kit? $850? Whoa. I don't have the total figure here in front of me, but I paid a fraction of that price for the kit.qship96 wrote:Why not order the complete under plenum kit from Joe at I.O.S., runs about $850-900.
I bet he has to.superuber wrote:Tell Joe Wes sent ya! Boy, it's come to me telling folks what wes should! Darn that BM'er site!
[/QUOTe
ULTI-HOSE Each $1,312.54 retail$984.44 your priceUltimate Engine Hose Kit - Q45 ('90-'93, w/o TCS) This is the ultimate engine hose kit for teh G50! Kit includes *under plenum air hoses**underplenum water hoses**EGR vent hoses**plenum gaskets**(2) knock sensors**knock sensor harness**injector harness**3 ft. of OEM fuel line**. It is truely everything you'll need to overhaul the engine of the Q45.
Here it is, slightly more than $850 for the 90-93 Q models-copied right off joes site for you.
Kit includes parts numbers: 11823-60U60 - $44.64 11823-60U61 - $40.25 11823-60U62 - $7.71 11823-60U63 - $17.87 11826-60U65 - $18.96 11826-60U66 - $4.48 11826-60U67 - $17.16 11826-60U68 - $6.69 11826-60U69 - $21.58 (Qty. 2) 11826-64U61 - $8.90 Plus all 8 plenum gaskets (not listed in illustration): 14032-60U01 - $4.29 Ea.
$244.14 on the site, less directly from Joe. I sort of purchased it.
The kit that you're describing is the complete engine hose kit. And it looks to be the one for 90-93's without TCS.
I believe I got the air hoses. The Ultimate kit seems to have air, water, and fuel lines. It seems that KS and harnesses are included as well. I wasn't looking to spend the $850 right now in either case. I purchased the other kit to have that done. If Keith deems it necessary for me to have the ultimate kit, then I can just nix the whole thing and postpone it. I just thought I'd be a doing some small lines and things. I was surprised at the girth of some of my new hoses.qship96 wrote:I ordered and had T3 install "the ultimate hose kit" compilation {855$$ for the 94-96q} every hose in kit was for "under the plenum", there is about 25-30 hoses under there! Double check with joe, but the kit you are referring to seems to be missing quite a few of the hoses under there!
Damn.Q45tech wrote:Simple after 100k/7 years the hoses you don't change will be the hoses that fail.After 18 years I changed all hoses 2 times and 3/4 of those - 3 times.
Just part of $3,000 annual cost.
Many of hoses won't kill the car if they fail but coolant hose [heater/rad/under plenum] and gasoline hose can make it a challenge to drive.
Always keep a dry chemical extinguisher in trunk.
Ok. That's what I was thinking. Damn, I didn't think about sparkplugs. I can do those in the driveway right? No need to remove the plenum, pretty straightforward right? I don't think the plugs and such will get here before Tuesday morning. I'm dropping the Q off as soon as the shop opens and I'll be around there until a little after lunch. I'll be waiting for my ride then.qship96 wrote:I suggest returning the partial hose kit for a refund, get the guides and valve covers/sparkplugs done NOW, and when funding is comfortable, reorder the complete under-plenum kit and install it, not cost/time effective to do some hoses now,some later-remove plenum ONCE and do everything under there as one operation.
Ok. I'll definitely get the plugs then. Idk, I'd rather not have to deal with the returning and all. I guess I'll just keep the hoses I have now and when I'm ready to do them all, get the ultimate kit - the hoses I already have. Thanks for the input.qship96 wrote:If you are paying to get your valve covers resealed, plugs go in at the same time for just a few seconds each, as all the stuff comes off in order to replace the valve cover seals- write down part number of plugs and get them locally at an auto parts store or local infiniti/nissan dealer if necessary=this will save YOU from doing it yourself later{many first time q plug changers need 4-6 hours to do plug change}, or paying a shop 4-5 hours labor to do it for you TRUST ME,GET THE PLUGS DONE WITH VALVE COVER RESEAL JOB!!!!!
AS far as returning the hoses, call joe and explain your concern regarding returning what you got now and reordering THE COMPLETE kit at a later date, you may be surprised{hint,hint} that he may be willing to waive the restocking fee in good faith for earning your repeat business in the future
If you strike out with waiving the restocking fee{I doubt it if you handle the call professionally}, your backup plan of keeping what you got and ordering the remaining parts at a later date when you are ready to do the plenum job seems a wise decision.
Good luck with your project next week, and drive the crap out of it once you are secure with the new guides!
