also be very sure to check the continuity between the harness plug (somewhere on the passenger side under the manifold, one of the 3 big harness blocks) and the ks itself.
I did the whole under plenum thing and replaced the KS to find out that the harness was faulty, and I just spliced in the old KS with a separate wire and dumped it somewhere else on the bank where the OS was supposed to sit (outside the plenum) and called it a day.... Might try to go back to fix it properly next time the plenum comes out.
If the scanner says you have a 0325 you are running at like 30% of the engine's capability at best....
Get that fixed and enjoy some tire smoking V8 torqueyness
