cccpman »
https://forums.nicoclub.com/cccpman-u36612.html
Wed Sep 19, 2007 11:20 am
well I recommend you save up until you can afford the under plenum job and have a day off
Both the spring and that particular screw clamp are EXCELLENT, dont replace either depending on what you have. If you go out and buy a new one, its going to have a screw on one side (but teeth along the entire clamp, you will know what im talking about because its all they normally sell), those WILL be the problem and cause leaks (been there). As for those two hoses, go OEM, I dont know why but fitting others has been a pain for me, also really hard to find one that will fit snug
That little Y shaped set of hoses and aluminum is possibly the worst part of engine work (in frustration). But a tube of RTV and use most of it, better safe then redoing the job
I would personally remove the lower intake manifolds too, its only a couple bucks to pay for the gaskets to re-seal them (you can clean them, they need it badly) and it really gives you a lot of room for that Y shape of death to work in easily to a 5 minute job, probably works out to be the same amount of time total either way. Plus you get to take a look at your fuel injectors - and clean them if you really wanted
ANY questions at all feel free to ask
