dlduscg »
https://forums.nicoclub.com/dlduscg-u64807.html
Wed Jan 06, 2010 1:54 pm
Actually my first problem was a tiny leak from the rack 6 months ago. I decided to get a rack from rack doctor and took it to a BG service garage to do the work. The new rack leaked worse than the old one, so I got another from rack doctor and had them do a complete BG power steering flush tech service. After 5 months the chatter began, then when the noise became louder, and other symptoms I checked the reservoir and found it to be bubbly. I followed the procedure for purging the air and all it did was push the fluid out, spurt a few bubbles and after the bubbles cleared, it was still at the same level as when I started, I did this several times, and not only is it at the same level, at the top of the reservoir, but I can no longer move the steering wheel with the engine running. except with extreme difficulty. I will probably have to have it towed somewhere to figure out what went wrong. BG service should be under warranty, but I do not count on anyone or anything being dependable after this fiasco.
