niznos »
https://forums.nicoclub.com/niznos-u14767.html
Tue Jun 29, 2004 5:39 am
If you still have the underhood insulation on there, you can snap it out and get the temps to lower a little. Every little thing counts. I've also removed the weather stripping on the rear of the hood, where it meets the cabin vents. This gives a little cowl inducted air to cool too. The thing about the weather strip is that once removed, you will be getting underhood fumes through that "cowl" into the cabin air intake, so if you are going to do this, you should keep it set to recirculate to avoid fumes. This is especially if you've got leaks on the engine. Remove the strip at your own peril, if the fumes are bad enough, it can make you sick.
