under drive pulley
kbflip02
Car: 1994 Infiniti J30
2006 Infiniti G35x
for those of you who have put one on your cars...do all the belts automatically line up right or have you had to space something out for them to fit????currently my water pump pulley lines up with my alternator but it sits 1/4 in too far forward on the crank....it was like that when we first put it in so we had to get a different belt to run A/C, water pump, and the tensioner...the power steering lines up fine...any ideas anyone....i can put the belts back on the way we had it rigged up before but i wanted to see if anyone has had this problem before and figured it out....
-K
yodawill2000
Car: 94 Infiniti J30
If its the correct pulley they should all line up.
Jakw
Car: 1993 J30
It'll line up, but you won't be using the OEM belts.
kbflip02
2006 Infiniti G35x
Jakw wrote:It'll line up, but you won't be using the OEM belts.
yeah i know it supposed to but for some odd reason it doesnt line up....havent changed anything else on the car...well see how it goes today...thanks guys...if i cant get the belts on the way theyre supposed to im just going to put them back on the way we had them so at least im up and running....i dont think it really matters as long as the pulley is turning the of the crank
