under dash wiring
onevia1800cc
Car: 1989 240sx ps13
ok on srswapdot com it says everything matches does that mean i don't have to splice any wires under the dash??? or do the plugs PnP
c-rad
Car: 1991 Nissan 240SX w/CA18DET
onevia1800cc wrote:ok on srswapdot com it says everything matches does that mean i don't have to splice any wires under the dash??? or do the plugs PnP
It's like 7 wires.... and yes, they need to be spliced together.
float_6969
The colors match, but the positions of the wires in the plugs don't. You'll need to cut and splice them.
onevia1800cc
ok got the motor in today that dash harness is really up in there,i hope i don't have to remove the dash
float_6969
Take out the glove box. It's like 4 bolts that hold the frame of it in. that should give you plenty of space.
Not_a_sr
Car: 90 ca18 pwrd 240sx FB
and you will have a few left over wires.
onevia1800cc
ok i just kut the ka harness for the plug, and spliced in the required wires from the ca. oh that little plug???any insight it didn't plug in? the small one wire one
float_6969
under the dash? There isn't one. If you've got one, it may have been something aftermarket that was installed in Japan. Pics would be nice....
rico05
Car: 1992 RMS13 w/ CA18DET
float_6969 wrote:Take out the glove box. It's like 4 bolts that hold the frame of it in. that should give you plenty of space.
I wish I had thought of that when I was installing mine. Freaking contortionist would have had no better of a time at it!
sdtouge
Car: 1990 240sx coupe
lol
the easiest way is to do it before you put that stuff in
the wires that go from the ecu to the dash can unplug at the ecu and under the dash, then just do it on a table or sometihng
onevia1800cc
yeah thats what i did just plugged it in
