Postby
hemifan87 »
https://forums.nicoclub.com/hemifan87-u172306.htmlSat Oct 22, 2011 7:25 am
thank you and lol I wanted the black but all they had was tran and its a pain to keep clean. I got the lights at advanced auto they were $25 for to strips. there called flex lights or something like that. They don't come with a plug so I used the plug that the red ones had.
Postby
Athikerguy4life »
https://forums.nicoclub.com/athikerguy4life-u182079.htmlSat Oct 22, 2011 8:15 am
I've seen those around. I'm thinking about getting the "LED glow" lights off of amazon. They are about the same price, but you get 4 light strips. They also come with no plug, but i Certainly have plenty of those lying around.
Postby
hemifan87 »
https://forums.nicoclub.com/hemifan87-u172306.htmlThu Oct 27, 2011 4:13 am
Thank you. I got them at advanced auto they are called flex lights they are a hard wire set up meaning theres no plug, just the ends of the wires. Iv heard of some people wiring it into the dimmer switch but I just used a dc end from the neons I had in there I'm doing the back soon.
Postby
veronicatheV »
https://forums.nicoclub.com/veronicathev-u192919.htmlSun Oct 30, 2011 7:53 pm
That looks great man. I got the same thing they are perfect for the black interior especially at night when you drop something while you are driving. Yours are white right? Mine are on when the lights are on so that would make it hard for me to handle.
Red makes any kind of dirt leaf or grass stand out really bad too as you can tell.
Postby
hemifan87 »
https://forums.nicoclub.com/hemifan87-u172306.htmlMon Oct 31, 2011 4:12 am
No mine are green lol I used to have red but but I got tired of it and they were neons so two of the tubes got broke so I upgraded to leds and changed to green, I wanted something different and you dont see green often.
Postby
hemifan87 »
https://forums.nicoclub.com/hemifan87-u172306.htmlTue Nov 01, 2011 11:43 am
Me ether lol iv seen a preview in the day I almost think they will be to much at night lol but they look good, I like them so much better then the neons.
Postby
hemifan87 »
https://forums.nicoclub.com/hemifan87-u172306.htmlWed Nov 02, 2011 4:08 am
The power is run to a 4 way splitter all hidden in the center console. on the back of the seats on the bottom there is a piece of black plastic I hooked them up there make sure to have enough slack so the seat can move, oh and they are wired the same as the front with an old dc plug I had.
Postby
Athikerguy4life »
https://forums.nicoclub.com/athikerguy4life-u182079.htmlWed Nov 02, 2011 3:18 pm
I'm planning on hard wiring mine through a switch so I can just flick them on/off. Not sure where to take the power from though. Does anybody know a good source for power? I'm not sure if any of the open fuse slots would be ok to use for accessory power.
Postby
veronicatheV »
https://forums.nicoclub.com/veronicathev-u192919.htmlWed Nov 02, 2011 7:47 pm
yeah they are its just a pain to do. But there is a constant 12v line that runs down one of the sides I actually think thats what I ziptied my Amp power cord too idk il look into it.
Postby
Athikerguy4life »
https://forums.nicoclub.com/athikerguy4life-u182079.htmlSat Nov 05, 2011 7:24 am
I might try this. If not, I was thinking of putting a second fuse panel in the engine bay to have all my accessories run off. That way there's no wiring going to and weird spots or any splicing into existing wiring. I was thinking i could screw it right into the battery tray on the other side of the existing fuse panel.
Postby
Jape »
https://forums.nicoclub.com/jape-u143261.htmlTue Feb 28, 2012 4:50 am
You can use an "Add-a-Fuse" adapter. They're real cheap and you just plug it into a spare slot in the fuse box or you can put it a less important fuse spot and it will still work for both the existing fuse and your light fuse.
