ThisIsSparTTa wrote:It's common for the high pressure power steering hoses to leak on the PS. Searching on them will tell you a bunch about them. Take care of it quick before it s*** on your alternator, like mine did.
I would tend to not think it is manual trans fluid, as that is pretty far back on the car (after the motor) and it sounds like what your referring to is closer to the front of the car. But I may be wrong...wardvonverde wrote:ThisIsSparTTa wrote:It's common for the high pressure power steering hoses to leak on the PS. Searching on them will tell you a bunch about them. Take care of it quick before it s*** on your alternator, like mine did.
I just checked my steering fluid (i.e. ATF) at work on my break. The level is all the way to the top, and reddish with that distinct rubber smell.
Also the oil pressure is fine, even after it hadn't been driven in 3 years. After I changed the oil, it's still reading at the same pressure.
I'm really worried that it actually might be manual transmission fluid, which I guess makes sense because it has a hard time shifting into and out of second gear sometimes. That's what my guess is, which makes me wanna puke.It also hates to shift when it's cold period.
I literally can't find any kind of guide, all the photos of most of the guides are just broken images because the hosting sites are now defunct. Any photo guides you guys know of?
Peace
I do have the climate control system set to 74 with a 3.6F variance. It blows out some cool-ish air, but I don't think there's any freon left in the system, because even when you put it on 60 it still blows ambient air, or maybe one or two degrees cooler. I'll have to get that fixed before summer, but I don't think it should be creating any condensation if there's no freon, right?itsa300zx wrote:Two thoughts, if the fluid appears to have no color:
1) Do you use the AC system, (ie compressor on to dry the inside cabin air) If yes might be just water dripping.
2) Check the tension rod bushings, they may be leaking a thick clear silicone goo.
ThisIsSparTTa wrote:MT Fluid would only be escaping the transmission and running backwards unless you spend a lot of time driving in reverse. There's no fluid reservoir for it in the engine.
There is a 2nd clutch bleed point on the passenger side near the PS resevoir. It uses brake fluid, which smells godawful, so I doubt that's it. Also, I haven't seen anyone saying that line is leaking, but anything is possible.
Tension rod bushings are a good call, especially if it sat for 3 years. Could have dry rotted from the lack of movement, and then cracked when you drove it.
wardvonverde wrote:ThisIsSparTTa wrote:MT Fluid would only be escaping the transmission and running backwards unless you spend a lot of time driving in reverse. There's no fluid reservoir for it in the engine.
Tension rod bushings are a good call, especially if it sat for 3 years. Could have dry rotted from the lack of movement, and then cracked when you drove it.![]()
I think this is probably the culprit, my question is that for a Z32 I've read that as the bushings wear out you experience some "shimmying while braking", however I experience significant shimmying while accelerating between 40-60 MPH, and the shimmy goes away above or below of the range. It also lessens significantly upon braking.
If I accelerate fast, it causes a godawful rattle on anything where the rubber trim has worn out.
It's actually one of the reasons my dad stopped driving the car, he claims a s*** auto shop bent the driveshaft. I think this makes more sense, what do you guys think?
.Don't rely on the OEM oil pressure sender, sometimes it can be off. I want to suggest a product to you, redline MT-90 you should order some and change the gear oil in the trans to that and see if it helps the issue.wardvonverde wrote:ThisIsSparTTa wrote:It's common for the high pressure power steering hoses to leak on the PS. Searching on them will tell you a bunch about them. Take care of it quick before it s*** on your alternator, like mine did.
Peace
