Under car skirt...
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Knightro2
Car: 2008 Nissan Versa SL
Wanted to see if anyone else has removed the "skirt" (not sure what to call it) that is under the car. This is the black plastic piece that you have to remove in order to get to your oil filter. It's a pain in the a** to remove it every time I do an oil change and I've already lost one of the screws so I use a zip tie every time.
I plan on taking it off and leaving it off the next oil change I do. Has anyone else done this? Any cons to it?
Promise Land
Car: 2011 Nissan Versa
2001 Chevy Suburban
1992 Ford Mustang
It is meant to help with airflow under the car. You might see a little drop in MPG without it, but it's not going to tear up the car.
I had the same frustration, so I just took my dremel out and cut a 6" wide x 4" section out below the oil filter. It stopped the problem of oil hitting it and going every where and it doesn't need to come off anymore. It would take me over an hour to get it off with the CF splitter on there, so the little modification prevents it from causing a problem.
Knightro2
Ahh..that's a good idea. Now I'll just have to figure what to cut it with since my Dremel went belly up a year ago.
Promise Land
2001 Chevy Suburban
1992 Ford Mustang
anything that will cut plastic. tin snips, heavy-duty scissors, etc.
Return to “Versa Technical Discussions”
