Uncharted territory
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
It might just be the time of year or the year in which most all the RB members are in the garage with there cars trying to get them running or fixed. Resulting in alot of "I need help" or "what is this" and similar threads (which are great for it shows we can help each other out).
However, after talking with some other members it would be great if we can get more technical threads back up and running.
This thread is to generate a melting pot of ideas, discussion, and plain brainstorming between us. This will get others involved or even talking about those things in which otherwise would of sat on the table.
For example..one area of interest that has and is "uncharted territory" is cam timing. As I have seen not many of us have mess with this and neither is there much data on this concerning our motors.
So drop a line in which might bring some "technical" discussion into play and others that are in the position that can write something up. (such as someone with stock cams and adj. cam gears to start messing with the timing and get on a dyno with some data down for us to use)
blurrbosi
Car: 240's
Seems like a good idea!
