Unbelieveable. 5 water pumps...
s10cky
Car: 1992 240sx coupe
I have been having overheating problems for like well 4 months now. I started by replacing the water pump. The minute I put this new water pump on water came pooring our the weep holes. I hope everyone knows what im talking about when I say the weep holes. the top one to be specific. well im like wtf...so I took that back and replaced it with another one...this time it took 2 hours. before coming out the weep hole. my conclusion was that air was in the system. I bled the system, and I drove the car all day, it did it on the way home....again. SO after talking around a mechanic suggested that maybe a headgasket its blown and its letting air in the system. soo I replaced my headgasket and radiator hoses as well as my radiator. and then the water pump again. I drove it for 2 full days and when I thought that everything was perfect. it did it again. my car is cursed. and I dont want to get rid of my 240sx just because this freak probem. could belt tightness or a cracked fan blade be cuasing this???
Modified by s10cky at 12:11 PM 7/26/2006
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
Get yourself an OEM water pump from a Nissan dealer. Many aftermarket pumps are just plain trash!
s10cky
Do you think that that will do? I mean these pumps are all the same kind, and are all from advance auto. I just think theres a possibility of something else causing it.
oh, how much are they from nissan?
mr2lickit
Car: looking
I had a similiar problem, all I did was reaplace the water pump! Did your pump come with a gasket to install it? I doubt you could be getting that many faulty water pumps (i'm also using advance auto parts water pump). All I did is use some gasket sealer and the gasket and installed the water pump. IDK if your thermastat would have anything to do with it?
s10cky
im not running a thermostat if that means anything.
teddy
Car: Saab Turbo and MR2
Do you have a new belt on there? Are you using the same water pump pulley for all of the pumps you've gone through? Are your heater hoses kinked in any way? Also, make sure you're using gasket sealer on the gasket to the water pump and allowing it sufficient time to cure.
s10cky
i dont know about the heater hoses. but the belts are the same belts. and they squeek alot.
teddy
If you're belts are squealing, then either A.) They're not tight enough, or B.) They're old and need to be replaced.
Try tightening them down some. If that doesn't fix the problem, then you may need a new belt. If that belt was either loose, or continuously slipping, it wouldn't be spinning the water pump as fast as it needed to be, which could cause overheating.
s10cky
what about the pump itself? do you think the belt can cuase that?
teddy
If you've gone through 5 different, then I doubt it'd be a problem with the waterpump itself, and if the belt wasn't loose/slipping, then it's not that either. If you watch and the pump is spinning, and the blades on the inside were fine when you put it on, and took it off, the problem is elsewhere.
If you've got a kinked coolant hose or blockage somewhere in your coolant paths, it would certainly cause the car to overheat. Do you still have the stock radiator? The radiators can get clogged up over time, especially with being so old. You may want to take your car to a mechanic and have the coolant system flushed to see if you have a problem.
Edit: Forgot to ask what the condition of your mech fan is? Is the fan kicking on? Do you still have the oem shroud on?
smithers584
i know what to do to fix it! Sell it to me! I am located in sumter, bring your car to me and we will take it to my shop and fix it, I guarantee you will have no problems after that. I emailed you once already, email me at [email protected] or call me at 2085201851, my name is josh. I wont charge you or anything, as long as you purchase your own parts.
Modified by smithers584 at 5:46 PM 7/28/2006
guyaverage
Car: Nissan 240SX Convertible
s10cky wrote:im not running a thermostat if that means anything.
That means everything. The thermostat, when opened, blocks the passage that allows coolant to bypass the radiator, and instead forces it through the radiator. By leaving the thermostat out you are allowing a large amount of coolant to not go through the radiator and instead it is merely recirculating back into the engine uncooled. Get a stock Nissan thermostat from a dealer and get it in there asap. DONT use an aftermarket one, they are notoriously crappy. You're not doing yourself any favors buy running without one. Just the opposite.
BTW, my water pump is from Advance and its been on 20k+ miles now and it doesnt leak a drop. I have another on a Mazda that has been on 2+ years and its still fine also.
