Mr.Nissan240sx96 wrote:my car is going to its 3rd month of not running, my ecu fried,so i got a new one, i changed all four ignition coils which were cracked, new battery, new water pump and it still wont turn on. Help me someone!!!!!!!!!!!!!!!!!!
dude ive herd this problem before..check to see if your harness has been done right!! make sure that you got the right box(ecu..red-manual,green-auto)..there's some variations i believe with the red ones..too..correct me if im wrong. when i got my sr20det blacktop it had an auto ecu for a manual one!!!...fu*cking p.o.s<osaka motors is where i got it from. i had to rebuild the fu*ker from the ground up. had a broken cam, 2broken rocker arms, and cut ecu with no transmission harness also make sure all the pins in your harness match up. thats wat i can think of now..im sure there's a thread in here if you still having a problem. good luck bud
