Unable to shift out of 1/reverse
mcd
Car: Infiniti QX 4
Dear pals, i have an awful experience with my QX 4, and sensors can make your life so miserable!!!....anyways, after settling issues with several sensor problems after some 3 years of driving i got stuck with my car not moving when in drive gear and gear 2 selection but only moves in 1 and reverse...maybe a safe mode state. I had changed the valve body and nothing happened, then the mechanic claims to have changed a sensor of some sort! which lies on top my gearbox( had to be dropped) and then i worked for two weeks and the problem has resurfaced again. My mileage is about 92k and no major issues with this ride. I dont trust what the mechanics are saying, can you help me with any suggestions. I am still stuck with no car movement in drive gear and gear 2 position but only in reverse and 1 position.
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Welcome to NICO.
What year QX4 do you have? Which sensor did your mechanic replace? Was it the revolution sensor? That's the only sensor that's on top of the transmission case I believe.
mcd
Car: Infiniti QX 4
Thanks for your response.
Its a 2001 model and yes its the revolution sensor that was replaced, and after some research, i was able to find out from the infiniti technical support manual, that i would need to service or change my forward clutch drum unit in the gear box.
Towncivilian
Did you run self-diagnosis described on page AT-47 of the factory service manual?
mcd
Car: Infiniti QX 4
No i have not. Will this help solve the problem? page AT-85 of the factory service manual gave two diagnostic items only and i have performed the first. So i'm thinking its the second. Do you agree?
