unable to remove LOWER CHAIN COVER - KA24DE
240ingthe240er
Car: Coupe
I just cant ****ing do it. The upper cover came off without any problems but this lower cover does not want to come off. I removed all screws/nuts, double checked and still nothing. The top half is almost completely off but the lower end of it doesnt budge in the slightest.
What the hell am I doing wrong?
djsilver
Hate to break this to you but: The oil pump is integral to the front cover but the oil pump suction pipe is bolted to the crankshaft main bearing girdle. You have to drop the oil pan and remove the bolt holding the suction pipe before you can remove the front cover. You really should have some sort of manual before you start this kind of stuff. The factory service manual is available in PDF format on the web, hard copies are available on Ebay and Haynes manuals are available at the local parts house. It really does make things easier...,
cmfireman
Car: '96 Nissan S14 SE
Hope you have fun with that, it's a pain in the a$$ to remove the oil pan off a 240.
You'll either have to unhook tons of crap and unbolt the motor mounts to jack the engine up (from the bellhousing) to get enough room to remove the oilpan, or you'll have to jack the whole car up and try to coerce the oilpan out the bottom.
amolao
Car: 1989 Hatchback (the first one...) w/ Autech sr20de S15
Both of my 240's are leaking around the oil pan and I'm really debating about going thru the process of taking the oil pans again to reseal them. It really was a pain last time I change the timing chains on both of them. Plus the automatic ones have a few more hoses that need to be disconnected in order to clear the area around the oil pan.
gthammers
Car: 1991 coupe, 1994 coupe
Just a bit curious - what are you doing? Chains and guides, or what?
dickie
Car: Killer Turtle
really hope he is doing something worth the trouble, because removing the chain guide (which is not really a solution to any problem anyways) only necessitates removing the valve cover...
drftnassmofo
Car: 84 s12 ca18et-TRADED
85 s12 ca18et-SOLD
92 fastback-SOLD
91 fastback-SOLD
90 coupe KADE swap-SOLD
06 Infiniti M45
im stuck on the same thing right now. im trying to replace the head gasket and i got everything off except the lower timing cover, chain, and headbolts. im not gettin why id have to take off the oil pan for this but i guess ill go take another look.
gthammers
Hy mofo,
If you are not replacing your timing chains/sprockets - don't worry about it. You do not need to pull the lower cover just for a head gasket. You may want to set the engine at TDC, compression stroke to make your life easier.
If you are already in and close to chain time, well... you know what you should do.
djsilver is dead on about the pick-up tube. That sucks #$%!
