Vettedrmr »
https://forums.nicoclub.com/vettedrmr-u30161.html
Fri Jun 08, 2007 8:27 am
Some of the things to check:
1. Did you remove the 3 bolts going from the oil pan into the lower cover and pop the oil pan loose?2. Remove the oil pump pickup once the pan is loose.3. Use a dead blow hammer and screwdrivers, wedges, whatever makes you happy, to pop it loose from the silicone seal.
HTH, and have a good one,Mike
