tee2 wrote: ↑Thu Jul 20, 2017 12:31 am
I was able to clarify with my guy earlier today, on the codes. It wasn't the MAF. The exact code, is P0505 Idle Air Control System. He told me that the idle air control valve, from last week, could be damaged, and that he would be glad to replace it free of cost.
As a side note, I managed to get the relearn completed at a shop, using a computer, instead of all that time consuming jazz that I shared with you.
If you wouldn't mind, could you please share your thoughts on replacing that corrupt IACV?
After the relearn, the SES light cut off. Unfortunately, it came back on after a couple of times
Here are my shared thoughts: I'm actually wondering if you read any of my posts in this thread.
I wrote on more than one occasion, given mine and other member's experience, that the problem was 99% related to a bad IACV.
I also talked about the relearn process, and possible damage to the ECM if you continued to drive with the bad IACV.
It seems you just didn't trust our/mine advice, and went ahead and wasted a lot of time, probably money, and resources trying to troubleshoot a problem that looked obvious to us.
Your mechanic is now saying that the new IACV he installed may be damaged because of the P0505 code. Right.
That P0505 code is not a good thing. If it does come back, you may still be dealing with a damaged ECM.
On a general side note, I never understand it when people come on to a forum like this, looking for help, and then getting all kinds of solid advice from experienced owners, and then ignoring their advice. Why bother?
