jwwpua »
https://forums.nicoclub.com/jwwpua-u28470.html
Mon Jul 25, 2005 1:06 pm
It turns out that the new control arms are 1/4" longer from the ball joint to the .. hinge (?) on the other end. That's what messed with the alignment so much. Since the tie rod ends are already screwed on all the way up to the end of the threads, I had a couple of ideas that I wanted to run by a professional.
The first idea is to replace the lock nuts on the tie rods with a thinner nut to allow the tie rod ends to screw on further, thus relieving the "pigeon-toed" alignment (right now there's a 1/2" difference between the distance between the back of the tires and the distance between the front of the tires). Would this be okay to try if I found a nut with the same threading, but just thinner than the one already on it?
The other idea is to grind down the tie rod ends enough to allow them to screw on farther and fix the alignment. I have 2 new extra tie rod ends in case I messed this up somehow.
Are these ideas viable? I don't think I can return/exchange the control arms so I'm trying to find an alernative to buying 2 more.
Thanks for the help!
