Drunkin' camera pics indeed, but you get the idea. However that yellow honey looking stuff is preventing me from removing the chip you see, It's underneath that and i doubt i can remove that without destroying the whole ecu. Also i fully understand what is involved in socketing/chipping the ecu i just cant get the old eprom chip out.themadscientist wrote:geez, those are terrible pics, is that a charcoal rubbing or was your camera drunk? APP makes brake lines not ROM chips so I doubt anything has been done to it. I am not burner so I am not 100% sure but I think you have to unsocket the stock chip and install a docking port (not sure what it's actually called) so you can pop the chip in and out without soldering it in each time.
You shure its not the N62 MAF? I dont think the J30 came with an N60 MAF. So the ECU is currently programed for stock injectors, MAF (N60 or N62) and cleaned up timing a little?driftin8ez wrote:Screws I can get to the front and back of the pcb however ever if i desoldier the eprom it will never come out from all that epoxy. I have a new idea anyway. I'm going to keep my ecu with the chip that I'm assuming is a stage 1 chip for Intake/exhaust/boost. It runs on the stock injectors and maf so it can't really be much more. Then I'm going to pick up a greddy emanage and update it for my j30 maf. This will be much better because if i ever want to get dsm 440's i can just update it through the emanage and away i go. Instead of having flash a new chip and all that jazz. So to make a long story short I'm going to sell my mine's tune chip if anyone wants it. It's a Mine's tune with updates for fueling/timing, up to 17psi of boost, J30 (N60) Maf, and stock injectors. I got it for $65 so make me an offer if you want it [email protected]
Yep timing and fueling are rescaled to run higher boost safer. Also, Yep it is an N60 MAF i have it sitting next to me right now. The j30 and maxima's with the VG came with an N60 maf. The 300zx's turbo or N/A both came with the bigger N62 MAF. The Z maf can supprt up to 500hp or something crazy high for our little CA's, The J30 (N60) Maf tops out at about 310hp which will never been seen by most ca's. I saw it to be much more fitting and far cheaper than an N62 maf. Also when i talked to speedlab I told them to tune it for a N60 maf regardless of what car it came from, That is the MAF that it is programmed for.AWDB12wagon wrote:
Cut your losses and sell the ecu on ebay as a stage 1 ecu, then use that money to buy an OEM ecu....OR trade it to someone on here for their stocker. You'll end up messing something else up on the board (resistor, capacitor, circuit, cable, etc) and then your stage 1 ecu will be worth nothing.driftin8ez wrote:What do you guys think? Would it be possible to take a dremel and cut off the epoxy. I would obviously not be able to save the chip but would i be able to salvage the board?
http://cgi.ebay.com/ebaymotors...d=1,1driftin8ez wrote:what are you looking to get for a stock ecu? I didn't take anyone's warnings and now you guessed it. Ecu is ****ed.
[email protected]
