Scott McLellan »
https://forums.nicoclub.com/scott-mclellan-u3074.html
Wed Oct 08, 2003 11:48 am
A new transmission- I'm sure it depends on where you get it done. If you felt brave you could do it yourself. I have, just make sure you have a couple of extra hands and a lot of patience. I'd guess getting it done somewhere could be over a $1000 but again I don't know. The other things like hydralic lines would probly be under $50. Slave cylinder would probly also be around $50 just for the part of course with probly a core charge.
I would highly recommend getting a service manual. I have a Chilton ($17) that works just fine. To bleed the clutch all you need is some fresh brake fluid, some clear tubing that will fit on the bleeding nipple on the slave cylinder (will work for bleeding brakes too) and a glass jar. First top off the clutch fluid reservoir with fresh brake fluid. Put a open end wrench on the bleeding screw/nipple thing and slip the clear tube onto the nipple. Put some brake fluid in the jar and put the other end of the clear tube in the jar so it is submerged in the brake fluid. Have someone depress the clutch pedal slowly 3 times and then hold it down the third time. While they are holding it down loosen the screw 1/2 a turn. If fluid comes out with no bubbles then sorry, you didn't need to do this. But most likely, fluid with air bubbles every now and then will come out. If this is the case repeat this process until no bubbles are present. Oh yeah, after you loosen the screw 1/2 a turn tighten it back after a sec or two. Then have your assistant release the clutch pedal slowly and repeat if neccessary. It might take 5-10 times or more to get all the air out if there is any. Good luck.
