Anyway, so I just went to lunch and when I got in my car at the office the gauges started doing crazy things. Now, I just replaced the alternator so that could likely be the culprit. I did just check and make sure it was installed correctly though, and it is indeed properly installed. Truck was parked in the sun, and the dash was pretty warm when I got in, but by no means scaldingly hot or anything.
So when I turn the key to "on," my temp and gas gauge shoot all the way to the top. My odometer reads "999999," and when I start the car the tach bounces between 0 and 500 rpm. When driving, the speedometer barely registers. At 40mph in 4th gear (I guess) it reads about 9mph. I don't even know what the heck.
I would love to hear your thoughts on this issue. I will also go back through and check everything when I get home.
Btw, the truck runs fine. Starts right up, idles fine, drives fine. Its just the gauges giving me problems.
truck is a 1998 D22 4wd XE.
Pictures!
Truck is running in the first pic.
