mikejax21 wrote:......does any body know where i can go to get an obd1 scan done that wont cost me an arm and a leg or where i can buy an infinity obd1 scanner i cant find one any where(keep in mind i live off of 700 a month)
mattd1979 wrote:....Hey Mike, I'm in Jax Florida also and I have a Consult clone adapter. ....Matt
It looks like Matt has exactly what you need. The Consult clone adapter is the cable that plugs into his laptop loaded with the free consult program that can read/clear codes and perform the diagnostics you're looking for. Log onto NICO, go into User Profile, and enable the PM function so you can contact Matt. You have an offer of help waiting.
Or you can contort your torso into the passenger side kick panel area and pull the codes manually by removing the ECU to get to the screw and LED on the back side. You'll need a phillips screwdriver and a 10mm socket/wrench. See InfinityGuy's post in your other thread and follow this link to
Checking ECU Codes. I recommend contacting Matt.
http://q45.org/techhelp.html
