s13240sxdrifter »
https://forums.nicoclub.com/s13240sxdrifter-u13284.html
Tue Apr 27, 2004 5:20 pm
the Ca16 crank doesnt work with the CA20 block. you have to use the CA20 crank and rods and pistons. i dont know if the CA16 head will work either. however, the CA18DE head will. you have to either maching the pistons down 2mm or get custom pistons with the wrist pin relocated. if you dont do so, the valves will hit the pistons. you can use the CA20E or CA18DE pistons as they are both the same bore. in order to get the high-revs like you want you'll have to micropolish the crank, cryo-treat it, get aftermarket rods and shotpeen them, get custom pistons, and get the whole assembly balanced and blueprinted. i'd get the pistons coated as well. to get high rev capability from the head you'll have to get high RPM springs and retainers. valves and a port job are recommended but not needed. also, you need to mount a custom timing belt and use the CA20 flywheel as the crank uses a different bolt pattern than the CA18DE. you can use the clutch from either engine. you also need either a high-output oil pump or a whole new oiling system. get every fastener from ARP, and use a standard Nissan headgasket. doing what i just told you will give you a CA20DE, or by using a CA18DET head, you'll get a CA20DET. compression will be around 7.8:1 with the CA18DET head, not sure about the N/A head tho. if you know what you are doing, it is real easy. it's also real easy to mess it up. my advice: get a CA18DET, a Tomei stroker kit, with titanium retainers, springs, get your head ported and polished, slap on a T04 or T78 or something large like that, and have fun and hope you dont blow anything up.
