boost_boy wrote:Damn Ryan, sounds like it could very well be your rod bearings. I base this off your original post and past experiences with the CA. Cheapy oil pumps are always suspect to me. I don't know if you got one, but I've come across a couple of bad pumps in the past and it has cost me dearly. Fortunately, the pump I use now is a beast and even at 800rpm, it sits at or around 30psi and when I jam the pedal after warm-up it shoots up realy fast to around 80psi. The cold starts are at 60psi at idle and if you blip the throttle, it goes to a little over 100psi before it warms-up settles down.
I would just start unplugging spark plugs wires to take the load off an individual cylinder to determine what it really is. IMHO, it takes an act of stupidity or a failed oil pump to trash the main bearings. The rods are usually the first to get smoked, so if after you pull the wires and you still here the noise, start with the rods and the bearings.
Lastly, if you slightly melt or trash a ringland from detonation or leaning out, then you will more than likely hear some strange noise inside the engine. Call me if you wanna rap more about it. I'm home until the 28th and then I have to return for the spanish program (Sucks). But at least I have a new job, gun, badge, bulletproof vest, blah, blah....... .
Dee
IDK, I'll drop the pan in the next few weeks and see. It hadn't change or gotten different and unless the CA is vastly different, I've heard rod knock before and this doesn't sound like that.
It wasn't a cheap oil pump, it was new from Nissan before they discontinued them.
As I said, I think the sound disappears once it warms up. The damn lifters make so much noise though it's hard to tell. I've really got to get that HG fixed so it's not leaking oil.
The ringlands are a possibility. They are forged, but this engine was my first tuning experience, it's high compression, and it was street tuned.
BACARDI_DWB wrote:dude why are you runing synthetic motor oil in it already??? you should run a regular motor oil to break it in. cause synthetic will not allow for any breaking in wear marks. do a google search and it will reveal more but any time you break in an engine you always use the standard engine oil NOT synthetic till at least 3000-5000 miles
LOL, comeon buddy, I'm not a total newb! This motors got over 30K miles on it! It never saw a drop of synthetic until it had 2 oil changes under it's belt (6K miles).
r34 gtr wrote:when i broke my engine in, i used dinosaur oil and freaking stood on it immediately after firing it up. as a result its kinda loose but i feel it runs like an absolute champ when warm. sure you get some bottom end noise and it leaks a lot of oil, but its not gonna be giving out on me.
ryan, get that head milled true. see if it fixes anything. if not it isnt exactly hard to change out the bearings. i did rods and mains on a jeep i-6 with the crank in the car. just use a soft piece of metal to tap the bearings into place. like aluminum, it wont scratch the journals. shouldnt cost you more than about $100 all said and done, and it shouldnt take but an afternoon. i know youve got the skills to pay the bills, so to speak.
I just recently bought another S13. I'm fixing the KA in it right now and it should be up and running in the next week. I'm gonna drive it for a couple of weeks to make sure I got all the bugs worked out, then swap the tag and insurance over, and pull the CA out of the current S13 and get the HG changed, check the bearings, rings, pistions, ect. And then swap the motors and sell this one.
I'm getting old and I want an interior....and a radio....and cruise control....and A/C.
