uk 200sx gauge cluster in a 240sx
david200095367
Car: 91 fastback 93 coupe w/s14 sr20det 98 s14 kouki
i want to know if a gauge cluster (instrument panel) from a s13 200sx from Uk will fit in my s13 240sx. Is it a direct plug and play or will it require some electrical work. The reason I am asking is because this cluster has a speedo that goes up to 150mph. So if i plug it in my 240sx will it read up to 150mph? Thanks in advance.
david
rico05
Car: 1992 RMS13 w/ CA18DET
As long as your car is DOHC it will work.
david200095367
so it will be a direct plug and play for sure, no custom wiring? so the mph will be acurate even though it goes up to 150mph right? Thanks
david
TheOne
Car: 93 240sx FB
i don't think it'll be accurate to 150, you will most likely have to do something for that, but i am not so sure.
david200095367
anyone else know the answer?
rico05
JDM ones and AUDM ones bolt right in. IF you have a HUD, you need the sub harness to the cluster, if not, just plugs in. Odometer will need to be readusted, but should go in no issues.
david200095367
ok i think this one is from United Kingdom it is probably the same as th AUD right? also how do i adjust the odometer? and the 150mph speedo should be accurate? Thanks guys for the help
david
rico05
Two screws on the back of the cluster hold the odometer in place. Pull it out and wind away. No clue about the speedo. No reason for it not to work, unless it has been dropped and is out of calibration.
david200095367
what i mean by if the speedo will work is because mine says up to 110mph and the uk one says up to 150mph. i want to know for example if i am driving 60mph the car wont say 90mph becuase the position of the needle on the usa one would have been 60 and the uk one is 90. the uk one should be calibrated inside already correct and if i get a speed eliminator i can go up to about 140mph?? thanks for the help everyone.
david
Modified by david200095367 at 7:51 PM 6/4/2005
Modified by david200095367 at 8:42 PM 6/4/2005
