3Q Jay »
https://forums.nicoclub.com/3q-jay-u16163.html
Thu May 17, 2007 7:04 pm
there is an o-ring behind the front cover down low, on the left side as you are staring fronm the front to the bacvk of engine.
they are infamous for leaking. you'll pull the front cover, you don't have to pull the head, but be careful of the portion of the head gasket that is between the upper and lower front cover. change your front crank seal while you've got it apart. also would suggest replacing tensioners even if you don't do the chains. remove the extraneous guides from upper chain (lot of posts on that).
