Are you at a complete stop while this is happening or is the car coasting a little?RobsPages wrote:It doesn't vary with engine or ground speed and is sometimes even there when idling at a stop light.
Is there an easy way to check that without having to take the wheels off? Otherwise, I'll make better note of that on my commute home.brainguyus wrote:
This sounds similar to what you get when a stone gets between the rotor and splash shield, but if the car is at a dead stop and you hear the noise it's something else.
It sounds like its coming from somewhere in front of the driver, towards the middle of the vehicle. I was going nuts trying to find a loose bit of dash board, closing vents, making sure it wasn't my keys, etc. I sat in the passenger's seat for about a half hour while my wife drove, and it still seemed to be more in the middle of the car near the base of the windshield, but that's a really un-scientific assessment.ITasteLightBulbs wrote:does the sound seem to come more from one side of your car?
Have someone stand outside the car while you move it back and forth slightly. If it's a stone behind the rotor it's easy to pinpoint.RobsPages wrote:
Fixed.ITasteLightBulbs wrote:Any car dealer is notorious for not wanting to fix a problem unless they can find it in the first 5 minutes. Or simply fixing the easiest candidate for the problem, whether or not it will actually fix the car.
I've never heard of this problem before - is it a Nissan thing? My last 3 or 4 cars have all had disc brakes - never had anything behind the rotor that made a noise or caused any damage.brainguyus wrote:My 2000 Frontier was always getting rocks caught behind the rotor. I'd just pull the wheel off and pry at the backing plate LIGHTLY (you don't want to bend it) with a large screwdriver until the debris fell out. Sometimes you need to fish around a bit but it'll usually fall out on its own.
I think that's most dealerships. This is why I wanted to gather as much info before getting there.ITasteLightBulbsNissan wrote: is notorious for not wanting to fix a problem unless they can find it in the first 5 minutes. Or simply fixing the easiest candidate for the problem, whether or not it will actually fix the car. So make sure you have records to give to Nissan''s HQ just in case they try to pull that crap.
I don't think it's just a Nissan thing. I've heard of this happening quite a few times with other makes.RobsPages wrote:I've never heard of this problem before - is it a Nissan thing? My last 3 or 4 cars have all had disc brakes - never had anything behind the rotor that made a noise or caused any damage.
Good CallDejaWiz wrote:
Fixed.
