BaliLover »
https://forums.nicoclub.com/balilover-u6785.html
Mon Jan 09, 2006 7:29 pm
How is it the shops fault you're too blind to see the temp gauge? If you had white smoke, it means the HG was ALREADY blown at that point and you had already overheated. I'd be willing to guess you just didn't see the temp gauge and don't want to admit it here because its embarassing.
Rule #1, ALWAYS watch your temp gauge.Rule #2, ALWAYS CHECK YOUR FLUIDS
You had this car back for weeks before anything happened. There is no way any shop could have known there was a problem since you were able to drive it for so long problem free.
If it was a stuck thermostat, that is also in no way their fault. They didn't make it, they just install it, and it was working fine when they handed you the car.
If you buy a brand new car, and the radiator hose busts and you drive it and let the engine overheat, very few dealerships would do anything for you. Your gauges are there for a reason, WATCH them. If something isn't normal, STOP DRIVING.
The headgasket didn't blow because a radiator hose came loose, the headgasket went because you overheated the car and continued to drive.
