boost_boy »
https://forums.nicoclub.com/boost-boy-u2853.html
Mon Aug 09, 2004 8:14 am
Quote »it probably just running rich, and you are having excessive cylinder washdown.[/quote] This is correct, though it's not cool at all. You will weaken your oil pump, wear out your rings, rod bearings and main bearings which will ultimately cost you your engine. Find out what's causing it run rich, but until then change your oil frequently.
Dee
