Bwana »
https://forums.nicoclub.com/bwana-u19793.html
Fri Dec 03, 2004 2:22 pm
Did you check the four nuts that hold the fan clutch to the water pump? Those could be loose/missing and cause that problem. Also, check the fan itself and make sure it's not cracking and coming apart, sholdn't happen if you replaced it with a new one but if you swapped a used one on there it could be deteriorated. Other than that, the fan clutch is the only thing I can think of causing the problem, but I'm not sure how it would. How about the shroud itself? Is it all properly fastened? I doubt it's being the water pump, but if it's not fixed soon it may take the pump out also.
