MarkEmark »
https://forums.nicoclub.com/markemark-u744.html
Mon Jun 06, 2005 5:22 am
Let me preface the post by saying that the engine is freshly rebuilt, has about 5 miles on it. Brand new thermostat, brand new water pump, brand new (last year) Koyo 2.1" thick aluminum radiator, fresh coolant at a 70/30 water/anti-freeze mix.
The engine was completely devoid of all fluids when I got it back from the shop, so I filled it up exactly like the FSM told me to...had the front end of the car a little higher than the rear, had the heater hose disconnected at the heater c*** after putting the heater dial in the car to hot, and had that little bolt in the intake manifold removed. I filled it up until coolant came out of that bolt hole, then I massaged the upper radiator hose so I could put in more coolant to make sure the system had the max amount of coolant (in the past, whenever I drain and refill coolant, theres never enough coolant and this causes the engine to overheat).
Anyway, I take the car out on its first ride (we'll skip all the problems I had initially starting the engine), and the temp gauge sky rockets, as expected. I don't like taking chances though, so I shut the car off at 230 degrees (I have a digital read out) and let it cool down, then eventually got home, but not before shutting the car off again once more to let it cool. By the way, the first ride was only 6 miles long....3 miles there, 3 miles back.
The weird thing is that right after I shut the car off when the temp gauge reads 230+ degrees, the upper radiator hose is boiling hot, and the lower radiator hose IS NOT HOT, AT ALL, and is as cold as it was before the engine was started, as if NO coolant is flowing through it. When I squeeze the lower radiator hose, there is definitely SOME coolant in it, however. I thought maybe I accidentally installed the thermostat incorrectly, so I took off the lower radiator hose/elbow and indeed, it was installed correctly. This is a brand new OEM thermostat, set to open at 76.5 degrees celsius. Every time I have started the car up, it has warmed up incredibly fast (75 degrees ambient temperature), and after I stop it, the same thing: the lower radiator hose is COLD. It's not just a *little*cooler than the upper hose, the way it should be...it's as cold as ambient temperature. Before the whole engine rebuild I would frequently check the upper/lower radiator hose after a long ride, and the upper hose would always be hot, and the lower radiator hose would be hot as well, although not AS hot.
The cooling system does NOT need more coolant, because after the engine completely cools down, the overflow tank has its level exactly where it should be: halfway between the "min" and "max" line. With the heater on in the car while the engine is running, it blows hot air.
Does this sound like theres still air in the system? I don't see how there could be, considering I filled the system up with coolant EXACTLY as described by the FSM.
I may go ahead and try to run the engine with no thermostat whatsoever to see if the thermostat is defective, but this seems highly unlikely because it is literally brand new. Also, I don't feel like spilling a gallon of coolant on my garage floor again when I disconnect the lower radiator hose/elbow.
Any ideas?!? Anything I can do without spilling coolant everywhere?
This is pretty frustrating because I finally got the engine installed and started (it's been out since mid-march), and now I can't even break it in safely.
Thanks
Marc
