uh oh spaghettio! (i think i did it)
turbo2nr
Car: 97 240sx (kouki)
well i think its come to it..
i noticed my car overheating on idle, and i burnt almost 2 quarts of oil between the oil change, and untop of that oil pressure is 15psi @ idle... not looking to good.
car doesn't pull as hard as it used to on 7psi, before i'd max the stock maf out around 5000rpms now i barely hit 99% by 6400..
so i decided to check my coolent and guess what its low, so i top it off and i look inside and what do i see?
BROWN CLOUDY WATER OF DOOM!!!
that would explain all the issues i stated above..
well i guess 20k on a boosted stock ka running 14psi at times will do that to you.. stupid head lift..
so now i have two choices, fix the head gasket. (get arp head studs and feltpro gasket)=300 bux
or wait a bit and finally throw in the carillo rods and arias pistons..(but i need to get arp main/head studs, ams oil pump and bearings, and i should do 264 cams and a small port and polish) so that about 1500 im calculating to do.. not to mention after that im going to need an aem to boost 25psi..
decisions..
all suggestions welcome.
neverlift
a headgasket and the arps should only run you 135, I picked up my arp head studs off nico for 94 shipped IIRC, felpro can be bought for 30 bux, then your upper and lower intake manifold gaskets and oil/coolant, around 200 should do it...
at least with the arps you can re use them, they are a pita tho IMHO...
