Ok I can't see any broken bolts, where were yours? I think it's just loose but I have to find someone with small enough hands to reach up between the fans and the exhaust to check. I really want to remove the shield and I've been researching and people seem to be fine after doing it. Only problem is I live here in Phoenix, could I have problems this summer if I mess with it?smokeshow11 wrote:i have the same problem it was the heat sheild,i just took it off becouse the bolts broke.everything is ok no fire yet... ,but if that isnt your problem then it maybe your cat.....good luck
