Ugly s13 glovebox fabric
SloS13
I fixed mine :)
[Zero-S]
Car: Tell me whats wrong with this picture. 3 240's, only one runs.
Did you just take the fabric off? I'm debating that right now, its oogly.
Big Perm
i have tried to get mine covered like that with no luck. I tried som balck vinyl but i kept having problems with the area underneath the latch. I could never get that recessed area to look right. Your's looks great. Any tips to get mine to turn out as good as your's did?
Thanks
Perm
SloS13
Zero - You'll want to remove all the screws, then remove the fabric, then sand off all the glue first.
Big Perm - I know exactly what you're talking about and decided to just not glue that part down at all. It bugged me at first and i tried to stretch it out enough where i could lay it down flat but couldnt. Once i turned it around and looked at the front, I realized it didnt look bad not-glued down.
If i decided to glue that part down, im pretty confident some stretching, a hairdryer and some superglue would work
driftaholic
Car: '91 Nissan RM S13
so is that vinyl? what kind of backing is on it?
SloS13
yeah, its vinly the back is like a white cotton mesh. Smells like it was dried in the sunshine
Antjaw
Awesome Job J92sDid you do the door inserts as well.. or is the burlap still there?
SloS13
burlap is still on the doors. Im thinking of re-using that fabric to store potatos.
Im kinda scared to start on the doors because i know it'll involve a lot of stretching and stuff to make it look smooth. Ive got to do some more reasearch on how to work with vinyl before i tackle that
[Zero-S]
Yeah thanks j92, I got that done yesterday, bout to start on the vinyl today. And I'll probably end up doing the doors as well.
SloS13
make sure you have PLENTY of clamps. I had about 10-15 to work with. The more you have, the faster you'll get done
[Zero-S]
You didn't glue anything, right? Did you staple it in like the OEM fabric was?
Bennyboy
Car: Beer
where do you get vynil
Nathan
That's frieking awesome...I might just have to do this myself :D but I'll use lots of epoxy.
