240marcuSX »
https://forums.nicoclub.com/240marcusx-u5199.html
Tue Jul 25, 2006 7:27 am
marble in a tin can and rattling are two different sounds.
marbles in a a tin can sounds like pinging, or detonation.
Rattling, like dragging a heavy chain on a wooden floor, is what the timing chain rattle sounds like, and its real quiet at first, so you cant hear it at higher revs.
valve tapping will get louder at higher revs, but you still might not hear it because of exhaust/engine noise.
first, check your oil, if your low, or leaking, it could be your valvetrain not getting the oil it needs, and its tapping, that has happened to me before.
If that doesnt help, maybe check your ignition timing, if its too advanced, it might be detonation, Or run a higher octane fuel and see if that helps.
Other than that, put your ear close to the valve cover (watch out for the fan and belts) and see if its coming from the very front of the motor, if it is, its probably the timing chain.
