I've been trying to decide what direction to go on my suspension upgrade. There is way to much bad info on these forums about coilovers, etc. If anyone has any actual experience with what I'm talking about below, please, please chime in.
The way the car, 93 nissan 240sx, came when I bought it is with lowering shocks and springs and 17 inch wheels. It's too low and it feels like poo. If I can't get a jack under the frame rails, then it's too low, especially for Louisiana roads. The whole suspension needs redone. I've already replaced all the bushings and now I need new shocks, springs and mounts. I don't want to buy things twice. I want a setup that I can live with now and for the future. I use the car as a dd and monthly autocross if it's running well that month.
My ideal setup would be a adjustable coilover setup with spring rates about 200 lb/in on both front and rear. I put a much lighter weight engine in the front, so I need front springs a bit softer than is normal on a 240sx (don't ask about the engine, it's a whole other story). They don't make coilovers this soft and they don't make coilovers with quality, tested and proven dampers. At least that I've found. That being said, I can save myself a lot of headache by just getting some stance or greddy coilovers for $1-1.5 k. People say they're fine, but I'm pretty sure they will be too harsh and I can't really get enough detailed info about them.
Otherwise I can get koni's with the ground control sleeves and springs, but these (i think) use the stock upper mounts. But, my mounts need replaced and I might as well go to pillow ball.
So, how about koni's with the koni sleeve and top hat, hypercoil springs, and the front pillow ball mounts by t3 and the rear by tein. The only problem with this is the details of the spacers, fittings, etc. Do the mounts come with standoffs? Will they be compatible with konis or the koni top hats? I cannot find this info. The price of this setup goes beyond what the coilovers, with all this functionality included, would cost.
This guy,
http://www.240sx.org/links/ins....html, comes real close to what I want to do, but he had to fab up some things that I don't want to and he had to use wheel spacers in the front which I also don't want to do.
Anybody have any experience with this stuff? I really want to get this right and could use the input. Thanks.
